T56 6 Gear engagement
Old Nov 20, 2024 | 08:56 AM
Ape Man's Avatar
Default T56 6 Gear engagement
Morning guys. T56 Question.
2002 WS6
I bought my car used in 2017, the guy who had it had just bought it to flip (he worked at a Gm store) - had his trans guy replace the following :
- After Market Clutch Kit NCF : 1104173 (Ideal Supply)
-12523250 - 5th/6th Gear Synchronizer
-24264182 - Slave Cylinder (Internal)
-12541299 - 5th / 6th / Reverse Shift Shaft Retaining Ring
-14058965 - 5th Gear Retaining ring
-12523253 - Multipurpose Retaining ring
-12523252 - Synchronizer blocking ring
-12523055 - Reverse Shift fork retaining ring
he issue I'm having (and it has never changed in ~40,000km and 5 years) is when its warm, it maybe 40% of the time will not engage 6th, no noise, just will feel like it went in but shifter just bounces and car revs (as its in Neutral), re attempting will allow it to go in. I've changed fluid to Syncromesh - no change. Now running MTF PN GM MT & TC Fluid - 88861800 - As per GM bulletin 04-07-30-037C (Replacement for Dexron III) - No change. When cold it is 100% fine, just intermittently does it when its warm. I plan on eventually replacing the oil pan, and rear plate cover, so while I had trans out to do that, I was going to entertain replacing whatever I suspected to be the issue.
Thanks!
Old Nov 20, 2024 | 05:43 PM
the_merv's Avatar
Veteran: Air Force
Bad Synchro, broke Keys, or Fork Pads worn out.
Pulling the Tailshaft you'll be able to get to all of them in minutes for a visual to see what it is.
Old Nov 21, 2024 | 08:06 PM
jmd's Avatar
jmd
Ideally, you can do new fork pads and done.
What I would look over is the full shift rail bushing, and the 5/6 shift rail assembly and related snap rings. Any break, or looseness in the internal shift parts can prevent full travel of the slider going into 6th.
Old Nov 22, 2024 | 07:49 AM
Ape Man's Avatar
I'm leaning towards shift fork issue myself.
I am going to swap in a Pro 5.0 shifter, brass shifter cup bushing and do the anti-venom mod. See how things feel/act after that
Old Nov 22, 2024 | 07:46 PM
the_merv's Avatar
Veteran: Air Force
If you bend the 5/6 Shift Fork you're doing something really stupid. Every T56 I build I put Brass Pads on every Shift Fork, worth the upgrade.
