Magnum F install
Old Dec 13, 2024 | 09:14 AM
connor neimetz's Avatar
Default Magnum F install
I’m looking into geting a Magnum F bc I don’t feel like rebuilding my trans and I’m planing on doing a lq9 buld down the line so ima need a better trans so I’m thinking about geting one now bc 3 gear pops out just wanted to ask what do I need to install a magnum f trans into my 2000 Camaro and is it worth it
Old Dec 13, 2024 | 05:57 PM
wannafbody's Avatar
Pretty sure you need a different pilot bearing. Everyone who has a MagnumF raves about it.
Old Apr 10, 2025 | 07:12 AM
zzracer's Avatar
I swapped one in a while back, well probably a year ago.. The one I put in was a direct swap. I didn't unbolt the bell housing from the block , left the clutch and everything in place. My buddy ordered it from Tick. That's an awesome transmission.
Old Apr 10, 2025 | 07:40 AM
george01transam's Avatar
Used a magnum f for my auto to manual swap. I had to get a bigger trans yoke. But everything else was for a stock t56 (bell housing, flywheel, clutch, pressure plate).
