5.3 build transmission questions
Old Jan 11, 2025 | 03:12 AM
Ehunt's Avatar
Default 5.3 build transmission questions
Hey guys new here. I apologize if this is answered I have been searching and can’t find anything in this. I have a NV3550 from a 1997 k1500 had a 5.7 vortec in it. I recently bought a 5.3 l59.
my question is can I use the flywheel from the 5.7 and bolt it to my 5.3 with the same clutch plate or do I need to buy a new flywheel and pressure plate and clutch?
I have seen mixed answers. Some say it will bolt right up some say it won’t.
thank you in advance for your help. I’m throwing this in my 97 jeep tj
Old Jan 11, 2025 | 03:32 PM
LS1 TJ's Avatar
I would check with the folks at Advance Adapters or Novak Adapters.
Old Jan 11, 2025 | 07:42 PM
the_merv's Avatar
Veteran: Air Force
People who say it'll bolt right up don't know Engines. Gen III LS Engines are a whole different Crank Flange bolt pattern than the Gen I & II SBC.
You'll need a Clutch kit for what you're trying to do.
