Tick master cylinder issue
Old Jun 6, 2025 | 01:43 PM
Tom729's Avatar
Default Tick master cylinder issue
I installed a Monster S series single disk, GM slave, and tick master about a week ago. My issue is that when I push in the clutch and put in gear, the car moves slightly. Now if I leave the clutch pushed in, take it out of gear and put it back in then it doesn't move. I also found if I push the clutch in, leave it pushed in for about 5 second and then put it in gear, the car won't move. I have the pedal just around the brake pedal height and it feels good, all the shifts are smooth. Even doing the REV test at 5k rpms the car doesn't move. Engagement point is around 1/3 up. I tried adjusting it out more and it still does it. Anyone ran into this? I'm thinking possibly air in the system, however I did bench bleed the master and then did a pressure bleed once it was all together. Any info would be greatly appreciated, thanks!
