CTS V t56
Old Jul 2, 2025 | 10:18 AM
TrevorHuebner's Avatar
Default CTS V t56
I知 looking at buying a t56 from a cts v without a bell housing. I知 new to t56痴 and was wondering what I need to swap to bolt it up to a lq4 in a 66 c10
Old Jul 6, 2025 | 08:35 PM
showdog75's Avatar
Unless you want to run a custom CV driveshaft which isn't bad just likely expensive you would want to get a gto main shaft and gto/f-body tail shaft housing so you can run a slip yoke drive shaft. Also get a f-body bell housing, the CTS-V bell housing will clock the Trans at a odd angle.
Old Jul 8, 2025 | 07:37 PM
the_merv's Avatar
Veteran: Air Force
GTO Mainshafts are super hard to find. That and if you have can build your own it helps.
I suggest finding a LS Fbody T56 and using that.
