3rd gear problems...
Old Aug 9, 2004 | 11:17 PM
NBM2001z28's Avatar
Restricted User
Default 3rd gear problems...
Sometimes when i shift into 3rd gear it'll kick out right away regardless of how much throttle, or if i powershift all it will do is grind and not go in. it started after about 12 track passes all with powershifting...
Old Aug 9, 2004 | 11:33 PM
Lastoria24's Avatar
syncros are gone, or the shift forks are totally bent to ****. There isn't a recall, but in Alldata, there is lots of late model f-body's with bad third gear shift forks, like they were bent improperly from the factory, i'd start by pulling the tranny, and stop power shifting
Old Aug 10, 2004 | 11:40 PM
ws.6kid's Avatar
This has happend to just about everybody put a pro 5.0 shifter or B&M shifter in so it wont happen again....
Old Aug 11, 2004 | 11:42 AM
calhoon's Avatar
Don't wate you time or money on any shifter. If you want to power shift( not use the clutch) resolve to spending bucks regularly rebuilding the trans. No synchronized trans will survive that abuse. Get an automatic for that kind of duty cycle.
Old Aug 17, 2004 | 05:48 PM
NBM2001z28's Avatar
Restricted User
I have a pro 5.0. it started because of that and the stops are right. It can just only take so much. calhoon is right.
Old Aug 17, 2004 | 10:31 PM
wrencher's Avatar
wrencher
It doesn't matter. If you drive the car hard the stock fork will show the abuse. A stock spec trans is just that, you have to build a good one.
