Clutch Failures - Why?????
Did you turn your flywheel, and if so did you space the flywheel properly??
Not sure what it is yet, like I said it only grinds going inot sixth, but I cn still get it into gear. Every other gear is fine.
!! Missing a pilot bearing won't have any effect on the sixth gear synchros, and they know it!! I had a missing pilot bearing for the first two years I owned my SS, and never had any problems with shifting, other than fluid return in the lines. After the drill mod, that went away too! And if you had a "misaligned pilot shaft", then every gear would be a bitch to engage. BTW: How do you "misalign" a pilot shaft anyway??
"Normally that is not covered b/c when a spring cover cracks and breaks it is due to input shaft misalignment during install or a bad pilot bearing, trans/engine mount or trans bearing. But since the clutch is like new I can get it replaced for you if you can send it in. "
. There has to be a failure mode somewhere! What is it: improper installation, incorrect flywheel/surfacing, driver error, hydraulic issues, etc? I'd like to think the quality of the clutches themselves is not so hit-or-miss, and there must be a few installation tricks/break-in procedures that make all the difference. Are there any clutch gurus out there that can enlighten us all?P.S. Sorry for the rant, but I'm getting tired of reading nearly identical posts over and over with no real solution in sight.
Wash
