HELP: Ram clutch slipping
Old Aug 31, 2004 | 09:27 PM
Juiced346's Avatar
Default HELP: Ram clutch slipping
I have a 910 disc, 402 p.p., (what i think is a 1055 f.w.), upgraded slave and t.o. bearing. along with Mcleod adj. master
Transmission was pulled due to usual 3rd and 4th gear problems.
Trans was rebuilt with viper internals.
Trans was reinstalled.
Now the clutch slips. I didn't touch the clutch once during removal nor installation. The master was bled extensivley, and there is no air whatsoever in the system.
The clutch didnt slip ANY before the removal, now it does, why?
TIA,
Dane
Old Sep 1, 2004 | 09:03 AM
Juiced346's Avatar
Not one person knows???
Dane
Old Sep 1, 2004 | 09:08 AM
Camaroholic's Avatar
Any chance you could have gotten hydraulic fluid on the clutch while bleeding?
Old Sep 1, 2004 | 11:52 AM
Juiced346's Avatar
Possibly? What is the likelyhood of fluid getting on the clutch during the bleeding process.
If there was fluid on the disc, what all exactly would need to be replaced? Disc and flywheel or could I just get the wheel turned.
Dane
Old Sep 1, 2004 | 11:59 AM
Inspector12's Avatar
TT-TECH Veteran
More than likely the disc and at that point you would want to turn the flywheel, and clean the presure plate very well with brake cleaner or equivilent.
Old Sep 1, 2004 | 01:05 PM
I personally don't like the GM design, where if you build up hydraulic pressure and crack the valve, it goes pfft! and sprays fluid everywhere - and since it's spraying against a socket, it could shoot back up in to the bellhousing. I could see it *maybe* happening. Oughta be some little splooge plate in there or somethin'.
Anyhow, if it's slipping, it needs to come out. I'd take it apart, and inspect the pressure plate and flywheel. I don't know if I'd necessarily resurface them or not... Depends on how they look. You might be able to just have new pads put on your clutch disc, or just get a new disc from Ram (me personally, I'd probably just get a new disc and call it good).
Old Sep 1, 2004 | 02:07 PM
Juiced346's Avatar
i just ordered a new disc. hopefully it will be installed fri night, test on sat. at the track.
Dane
