RAM clutch question
You *may* need to shim the slave, instead of focusing on the master. By shimming the slave away from the face of the trans, you're placing it closer to the clutch, and improving the disengagement when the pedal is pushed in.
Honestly, I'm not sure where to get the shims, but I know that some clutch kits come with them... so someone like Thunder might be able to help with that.
My flywheel was resurfaced only .008 and i could barly make up for that with my adjustable master.
