Clutch Chatter?
Old Sep 4, 2004 | 06:55 AM
StoreKeeper99Z28's Avatar
Question Clutch Chatter?
I got a Spec 1 clutch put in about 300 miles ago and I still get clutch chatter when I start out.
I had the flywheel resurfaced and all new hydralica (sp) put in.
Is this normal ,break-in period?
Best way to break it in?
Thanks in advance
Bruce
Old Sep 4, 2004 | 03:18 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Wow, you really shouldn't be getting any chatter with that setup since it is damn near just like the stock clutch. It sounds like you did everything right install-wise...hmmm.
Normal break in period: ~500 miles.
Best way: in town driving where you are shifting a lot. It helps everything get worn properly.
You may have gotten a bad one...if it doesn't go away, I'd call Spec and get another one. I'd expect a stage III to do it, but not that one.
Steve
