problems shifting from 2nd to 3rd
Old Sep 5, 2004 | 12:14 AM
Jimmy's Avatar
Default problems shifting from 2nd to 3rd
I just installed a spec stage 2 clutch with a fidanza aluminum flywheel in my 2000 Trans Am. I used the shim provided and upgraded the master and slave. I did a 550 mile breakin with at least 400 of those miles being city miles. I am having problems shifting at hight rpms. I can shift from 1st to 2nd but when i try to shift to 3rd it is like it hits a wall, it just wont go in. Under normal conditions, it goes in. I did some research and i was thinking that maybe the drill mod would help but i thought that was done to cure the problem of the clutch pedal sticking to the floor at higher rpms. My clutch pedal hasnt stuck to the floor. I know 3rd gear can be hard to find but this feeling is different. The clutch pedal pressure is pretty firm and the engagment is about like stock now, so i thought the hydraulics were bleed good. I was going to try to bleed it again and see if that helps. Will the drill mod help? Any suggestions would be helpful.
Jimmy
Old Sep 6, 2004 | 09:15 PM
Jimmy's Avatar
Can anyone tell me what problems the drill mod will fix? Or if wrapping the steel braided line with some kind of heat protector will help improve shifts. Need help, please.
Jimmy
