PHC Clutch - - - Need help PLEASE
Old Sep 13, 2004 | 11:41 AM
Southern's Avatar
Question PHC Clutch - - - Need help PLEASE
Please help. I have a 2000 Pontiac Firehawk with a 6-spd. trans. and LS1 engine. I am having to replace the clutch and it is a PHC. I cannot find one of these ANYWHERE. I just recently purchased this vehicle and have tried another clutch but it won't work and was advised only the same clutch can go back in. Does ANYONE know where I can find this clutch. I feel like
Old Sep 13, 2004 | 09:10 PM
wrencher's Avatar
wrencher
Why not get a whole clutch set? PHC stands for?
Old Sep 14, 2004 | 09:58 AM
Southern's Avatar
that's just it. I don't know what PHC stands for. If i use another clutch i have to get a new slave cylinder, etc. This setup doesn't even use a slave cylinder. Kinda like it is its own system. Never have seen this type of setup before.
Old Sep 14, 2004 | 08:39 PM
wrencher's Avatar
wrencher
THese cars all use the same throw-out/slave cylinder set-up. You can put what ever clutch you want in there. I recommend on replacing the slave/throw-out while your in there.
Go to www.installuniversity.com & click on LSX , then click on install documents.
Scroll down to the transmission section & check out, the McLeod clutch install & also the drill mod & Mcleod master install. That should help you out.
