EVERYONE with Pro 5.0 please help....
1- I used black paper gasket material and black RVT sealant, I also cut and used a small peice of black paper gasket inbetween the stick and the shifter. But I still get a ton of vibration noise out of the unit at higher RPMs.
2- The stick will not center when it's not in gear.
I have read that many others have also had these two problems, and I'm not looking for solutions as I've done my research and will try some of the things that have been recommended by others before. But here is my issue.
If the springs are week in the shifter and it won't center properly, WHY DOESN'T THE Pro 5.0 INTALL STRONGER SPRINGS? Well I called the company and spoke to Joseph, and he blamed the issue on my transmission springs going out. He also said they they have NEVER had anyone call them and complain about this issue, and they test all their shifter before shipping and find them to be perfect. But I have read many people here on this board complain about the springs being too weak.
What I'm searching for is the truth from all you users of the Pro 5.0. How many of you have had issues with this shifter? How many of you have not liked this shifter, and why? How many of you have had to replace the springs so it would center properly?
I told Joseph that I was going to post this question here and email him the responced from actual users of this product. So please chime in if you have anything to say good or bad. Joseph told me that message boards are mostly lies and other manufacturers that slander the competition. Let's show him, good or bad, what actual pro 5.0 users have to say about their shifter.
as far as the centering spring, mine seems to work just fine. overall, i preffer the pro5.0
Sincerly,
Mr Hurst -CEO (ha,Tudds)
) so I could tighten them on the passenger's side of the shifter stick. This seems to help keep the shifter stick from rattling too much. Don't get me wrong, my shifter does still rattle at WOT, but substantially less than when I first got it. Also, for the centering problem, I took apart my stock hurst, and took the springs to a local hardware store. I bought some springs that fit in the middle of the stock ones and cut a few coils off since they were a little longer than the stockers. I then installed them in the Pro 5.0 (added to the ones already in there). They work sort of like a dual valve spring with the smaller spring on the inside of the larger one. This has pretty much fixed the centering problem with the shifter. All in all, I really like the Pro 5.0 and I'm glad I got it. I wasn't really upset that I had to mod it to work the way I wanted it to, but maybe that's because I'm always looking for a reason to work on my car?
1 - Almost everyone has shifter vibration noise. Sounds like this is simply part of adding an aftermarket shifter.
2 - Although I haven't counted exact numbers, I would say around 50% of the time the springs are weak, and this causes a centering problem on the 1-2 side.
3 - Even with these two problems, many people out there love the Pro 5.0
Anyone else want to voice their thoughts?
as far as the noise i have it and pretty sure they all have it. but if you want something quite put the stock shifter back in the car and let it be. i have learnd when
you plan on modding car you cant have best of both worlds.
