Conversion 87 Corvette Transmission
Old Oct 6, 2004 | 02:52 PM
106mike's Avatar
Question Conversion 87 Corvette Transmission
Need to know if/what are any modifications needed to convert 4+3 to 5 or 6 speed standard transmission? Need transmission and price.
Old Oct 6, 2004 | 03:19 PM
Third Gear's Avatar
- Mike, they did not make an 83 Corvette, I'm guessing you mean 84.
- I think some people have had great success swapping in a ZF 6 Speed in place of the old Doug Nash one since they both come from a C4. I'm not sure what a ZF would cost right now. Perhaps around $2000 + core. Plus I'm guessing you'd have to get the correct driveshaft since I doubt the two transmissions are the same length. Also you might be looking at a new flywheel to match the ZF as the ZF uses a dual mass setup, and I'm not quite sure what the DN 4+3 uses. ZF clutch hydraulics will probably be needed as well. I think the ZF is the most painless since it was installed on 89+ C4 Corvettes, and the parts are still available.
- I've heard of others swapping in transmissions other than a ZF, but it requires more work. I think a Richmond 6 speed would also work well. But basically transmission swaps aren't cheap, and aren't always easy. Maybe someone else more familiar with transmission swaps with chime in.
Old Oct 6, 2004 | 03:26 PM
zippy's Avatar
1983 Corvette. that's the funniest thing i've heard all day...
Old Oct 6, 2004 | 10:46 PM
KimberWS6's Avatar
I've saw 1 '83 vette....................
in the Corvette Museum in Bowling Green,KY
Old Oct 8, 2004 | 12:32 PM
106mike's Avatar
Question conversion of 87 corvette transmission
I need information on conversion of 4+3 transmission in a 87 corvette to either 5 or 6 speed.
Old Oct 8, 2004 | 02:25 PM
ws697's Avatar
im guessing that you would need everything having to do with the tranny out of a new c4 eqipped with a m6. this would pry be a easy swap if u had a wrecked donor m6 car but im not sure.
