Chopping the stock shifter?
Old Oct 14, 2004 | 12:16 PM
FastWS6TA's Avatar
Default Chopping the stock shifter?
So i wish that the throw on my stock shifter was just a little bit shorter. Is it possible to cut off some of the stock shifter in order to reduce throw distance? If so, then how do i perform this task? Thanks
Old Oct 14, 2004 | 12:23 PM
technical's Avatar
A short stick would result in a shorter throw yes.
If that's the route you want to go, cut out a section of the stick and weld it back together.
Old Oct 16, 2004 | 03:41 PM
FrankSS's Avatar
you could do it too, just cut a section out and retap the threads on the end you cut. a local hardware store could prob do it for you. or u could maybe find a bolt of some sort with the same thread pitch on it.
Old Oct 16, 2004 | 09:43 PM
14u2nv's Avatar
Technically the distance between gears isn't shorter, just the feeling is. With a lot of practice shifting with a stock shifter doesn't take any longer then a shortened shifter.
Old Oct 20, 2004 | 08:27 AM
David 2002 WS6's Avatar
Lightbulb My 2 cents...
I'd recommend buying an aftermarket short shifter handle and swapping that in. They don't cost too much and this gives us the ability to return back to the original shifter handle for whatever reason (for example, you don't like the chopped shifter, you don't want the "down time," you later decide to sell your car and want to return it to stock condition, etc.)
Old Oct 21, 2004 | 03:03 PM
JTM's Avatar
JTM
A sponsor off the board UMI had some short sticks for stock shifters, etc... for $19.99
Old Oct 21, 2004 | 04:44 PM
peteZ's Avatar
Just buy one of the short sticks out there. For $20, it's not worth your time and materials to do it yourself.
