noise problem help
Old Oct 14, 2004 | 06:32 PM
jcooke's Avatar
Unhappy noise problem help
recently had trans rebuilt [t56] while apart replaced lux replacement fllywheel clutch throwout bearing .replace factory slave .when put together made chirping / removed again and remove roller pilot bearing replace with brass bushing reassemble /assembled again and still makig a tapping noise : changes when clutch is depressed anny advice helpful 1998 trans am
