Shifter movement when accelerating
Old Oct 17, 2004 | 07:25 PM
Black SS's Avatar
Default Shifter movement when accelerating
I have check both the trans. mount and motor mount and they look to be ok.
How much movement should the shifter have when accel. hard? I have only had the car for 2 weeks and am still getting familiar with it and f bodies in general. Thanks for experienced advice.
Old Oct 17, 2004 | 11:43 PM
Mike 01WS6's Avatar
Mine has quite a bit of movement under acceleration. Unless you start hearing a clunk when you gas it, your tranny mount is fine. It is normal for it to rotate a little since the driveline is not anchored to a fixed point at the rear of the car (IRS), but rather floats because it is a live rear axle setup.
Old Oct 18, 2004 | 03:36 AM
Camaro01SS4life's Avatar
U gotta love the torque from the LS1...Mine does the same...
Kevin
Old Oct 18, 2004 | 08:40 AM
Black SS's Avatar
Thanks guys...yes I love this car's torque
