Street Twin Problems
The result of this, was regardless of how much I pressed the pressure plate in, the bottom disc would not disengage.
In my case, because it's a ford it has a release fork, so the clutch release mechanism was still working when the trans was out.
This made it easy because what I was able to have a buddy push the clutch in, and I stuck a spare input shaft in the clutch one disk at a time. It was obvious when I was able to spin the top clutch but not the bottom clutch that I had it shimmed wrong.
Steve
Ben
Steve
