Spec 3i Help!!! Vibration
Old Oct 28, 2004 | 03:19 AM
y2kpewterz28's Avatar
Default Spec 3i Help!!! Vibration
Just installed the 3i with new billet steel flywheel, have about 400 or so miles of stop and go driving on it and no track passes on it. Problem im having is the entire car starts to vibrate really bad when in 2nd gear above 2k rpm. Anybody with this problem, please let me know if so and how to fix.
Old Oct 28, 2004 | 06:30 AM
Slowhawk's Avatar
LS1Tech Sponsor
Is it 2k rpm and up in 3rd/4th too?How about while stopped,just revving it up past 2k?
Old Oct 29, 2004 | 01:59 AM
not very much at idle, but does vibrate alot 1st thru 3rd above 2k rpm. Any ideas?
Old Oct 29, 2004 | 05:06 AM
Slowhawk's Avatar
LS1Tech Sponsor
Sounds like it is just rpm related,not gear or speed reelated.
Here is a few problems I've seen that might cause this.
Out of balance clutch assembly -highly doubt it.
Improper install -very important to torque all clutch parts properly.
ussing stock resurfaced flywheel that wasn't balanced after resurfacing.
Old Oct 29, 2004 | 07:29 AM
thanks for the info.
Old Oct 29, 2004 | 07:34 AM
Keenov's Avatar
Mine wasn't balanced and I have no chatter or vibration what so ever. Just FYI
Old Oct 29, 2004 | 12:58 PM
SAM98WS6's Avatar
check your clutch/flywheel bolts to see if they are all torqued properly...
Old Oct 30, 2004 | 05:39 AM
oramac68asf's Avatar
I too have a spec 3 and mines doing the same thing, but its not new its got about 15k or so on it and i just noticed it tonight. Its more when i punch it in secound from about 2000 rpms anything above that is fine. Any ideas?
Old Oct 30, 2004 | 03:34 PM
z289899's Avatar
Mine is shaking like crazy usually around 60mph and up in 5th or 6th. But it is worse in 6th than 5th. Around 80 in 6th it gets where I don't even want to drive it anymore. But driving around town it seems fine. When I rev it it doesn't seem to do it either.
Old Oct 30, 2004 | 06:31 PM
well since my last post i lost my clutch thats why mine has been vibrating. Mine basically went out on me completly today. THIS SUCKS!!!!!!!!
Old Oct 31, 2004 | 12:14 AM
97M6Formula's Avatar
mine vibrated when i lost one of the springs in the disc
Old Oct 31, 2004 | 10:30 AM
Keenov's Avatar
My Stage 3 doesn't vibrate like that, but it isn't a 3i.
