Problems bleeding the clutch
Old Nov 9, 2004 | 12:13 PM
SSBRONCS's Avatar
Default Problems bleeding the clutch
I'm having trouble bleeding my clutch. The pedal just sticks at the bottom, and has no pressure. Oh yeah I did install the upgraded hydrolics. Any suggestions on the easiest way to bleed the clutch on my ls1 would be greatly appreciated.
Old Nov 9, 2004 | 03:19 PM
98Blubrd's Avatar
I used a mighty vac and rigged up a tool to push in the spot that goes into the tranny (slave cylinder or master cylinder i cant remember what is which). If u dont know what the mighty vac is which i didnt until i saw a pic its just a little hand pump with a cup on the bottom when u pump it you can get it to like 40 psi. Just make sure you keep the resivour filled up or u will just pull air through it again. I had my friend keep filling up the resivour and i was doing the bleeding. It worked great. Do a search on Bushmans Bleeding method or just bleeding method and u will find something.
Old Nov 9, 2004 | 04:30 PM
SSBRONCS's Avatar
thanks i'll try that today
