I need clutch help
Now I go to the track on a points day to try to get a 60' that does not start with a 2. (my avg 60' is 2.2). On my 1st launch the car gently accelerates and the RPM is at 6000. This gives me a great 14.5 @99. The car reeks of clutch when I get back to the staging lanes. I try 2 more passes about 1hr apart with a gentle street launch and get a 12.9 at 112.
Now my questions are is the clutch shot? or is the car just too much for its holding power?
If it is gone what should I replace it with? I no longer have the stock flywheel as the McLeod comes with its own.
Also I have the McLeod adj master cyl installed with the drill mod, Will any other clutched requier me to swap that out ?
This clutch has about 5k miles and 50-75 runs on it and 10 autoxes.
Any suggestions?
