drill mod question
Old Nov 30, 2004 | 03:01 PM
ssPetess's Avatar
Default drill mod question
I'm going to be ordering a McLeod twin disk kit which comes with a new master cylinder. Will I need to do the drill mod? I am guessing you reuse the connecting hose, and that's the item which needs drilled, correct?
Old Nov 30, 2004 | 03:27 PM
SStillSSmokin's Avatar
Yes, I would do the drill mod! I just did mine while doing my clutch install 2 weeks ago, and it was pretty easy. Except for getting the master cylinder back thru the firewall It would prob. be easier if you have a helper to guide you from the inside. I used the write up on www.installuniversity.com as a guide.
Good luck!
