LT1 clutch problems
Old Dec 6, 2004 | 10:39 AM
Chuckels's Avatar
Default LT1 clutch problems
I put a Mcloed clutch in my car about 3k miles ago and like the clutch but every so often when i push the pedal all the way in it would make this grinding kind of sound but if i drove it for a minute it would go away. When I was at capitol raceway today after my second pass is started doing it really badly to the point that I think that i need to do something about it. I let it cool all of the way down and it still does it where as normally it would have gone away. If i try and start the car with the clutch all the way to the floor it wont b/c its like something is binding up in there but if I let the clutch out just a little it will work fine. I can shift gears fine if just dont push the clutch all of the way in and it doesnt make any noise. Thanks for any help.
Old Dec 7, 2004 | 12:30 AM
LS1 powered's Avatar
Same thing with one of my RX-7's. (LT1 T-56)
Shorten the "throw" at the pedal if you can. Is there an adjustment (at the pedal)??
Old Dec 7, 2004 | 06:57 AM
IllusionalTA's Avatar
The Fork is contacting the PP>. are you using a twin? or a single? The twin's are coming w/ the adj. master.. so you should be able to adjust the rod..
Old Dec 7, 2004 | 10:30 PM
Chuckels's Avatar
I'm using a single. I dont think that you can adjust it other than a master cylinder. I'm going to see if the T bolt that holds the fork has backed out some or just look for any problems. I'll keep posted on what has happens. Thanks for your idea's.
