Master Cylinder????!!!Slave???!!
Old Dec 16, 2004 | 07:20 AM
DarkAzNite's Avatar
Default Master Cylinder????!!!Slave???!!
Hey all, I have searched and read for hours and can't figure out what the hell the problem is...I replaced my clutch this weekend Spec Stage III, it has an upgraded slave cylinder from the last clutch job, I placed the shim behind it. I have the drill mod, had the flywheel resurfaced...didnt bench bleed cause didnt have the mighty vac at the time. Anyway...the stupid clutch will not build up or hold pressure, I tried the 30 pump and open the bleed valve, checking fill cup and repeat method, tried the mighty vac too, I STILL HAVE NO PEDAL PRESSURE and it is driving me nuts. I was thinking of making the other home-made bleeder from these instructions: http://www.ls1camaro.net/sections.p...rticle&artid=71
But I wanted to know how can I tell if my master or slave is gone bad?
Any help is appreciated...
Old Dec 16, 2004 | 09:43 AM
Bugsquawsher's Avatar
You really need to bench bleed the master if you had it out and appart.
