Help With Tranny
Old Dec 19, 2004 | 11:43 PM
SLP4CamaroSS's Avatar
Default Help With Tranny
ok i have a 2000 Camaro SS m6 i just changed my tranny fluid with Mobil 1 ATF. my car shifts great feels good but when im in 2nd gear and i want to downshift into 1st it grinds. for it not to grind i have to downshift at 20mph and below.but if i go from 1st to 2nd doesnt do anything. before with the stock fluid i had in it i could downshift into 1st at 35mph and below. if i can get some input guys do i need to bleed the clutch and adjust clutch spring or just change back to stock fluild i think its the fluid thanks. and another question sometimes when i try to start the car it doesnt start it might happen maybe 1 out of 100 times i start the car. and when normal driving the pedal might not come all the way up just like an inch off the normal. do i need to adjust the clutch itself thanks guys
