T56 third gear and drill mod question
Jordan
It suppose to make the Clutch grab faster.
I'm not sure there is any documentation on how much it really helps.
Most likely its a , Hey I just did all this work it better feel different thing.
As far as the third and fourth Gear.
They both work off the 3-4 Synchro assmebly (duh)
But in this assembly are some Keys.
they hold the blocker ring from spinning.
these are stamped steel and have a tendacy (sp) to Break
some get jammed where they shouldn't most just find there way to the Magnets and hang out there.
But being there they aren't doing there job anymore
The Blocker rings job is to get that perticular gear up to speed of the Shaft before the Teeth have to try and mesh.
If those keys are gone , you can see the problems that will follow.
Check out that thread, I had the same problem. Rebuilding it now
Good luck!
Jordan
