Are Gear Sets Interchangeable
Old Jan 5, 2005 | 11:13 AM
Juiced's Avatar
Default Are Gear Sets Interchangeable
I was wanting to put the m29 Gearset into my vettes t56, is that possible?
Old Jan 6, 2005 | 09:54 AM
calhoon's Avatar
if by m29 you mean the tri-cone synchro set from a GTO, yes it will fit in your vette. Actually it is the same as the Z06 set.
Old Jan 6, 2005 | 10:58 AM
Juiced's Avatar
by m29 i mean the gearset form a 93 TA with the .67 6th gear.
Old Jan 7, 2005 | 07:03 AM
calhoon's Avatar
No that gearset has a 3.36 1st ratio (and the 6th is actually.62 - there were no t56s with a .67 6th) It will not fit because of the synchronizer differences and the input gear face width is narrower and a different cutting ( ratio) than the std. C5. If you have a Z06 T56 the ratio is the same but the issues with the face width and synchronizer remain.
Old Nov 24, 2010 | 09:52 PM
Jessman's Avatar
Close, but you forgot that there are 2 different 93 T56's. An M28 and an M29.
A=94-97 T56 (MN6?)
B=93 M29 T56
C=93 M28 T56
Gear A B C 4L60E
1 2.66 2.97 3.36 3.08
2 1.78 2.07 2.07 1.62
3 1.30 1.43 1.35 1.00
4 1.00 1.00 1.00 0.70
5 0.74 0.80 0.80 N/A
6 0.50 0.62 0.62 N/A
Rev 2.9 3.28 3.28 2.29
Torque Capacity (lb/ft) A-450 B-400 C-350 4L60E-350
Old Nov 24, 2010 | 10:52 PM
85MikeTPI's Avatar
Wow, way to open up a 5 year old thread..
Old Nov 25, 2010 | 07:15 AM
calhoon's Avatar
REALLY!!!!
And to actually add nothing.
BTW I did not forget anything. Those early units both have the same interchagneability problems.
By Brett Foote | 2026-06-04 05:00:17
