Damaged Clutch Disc?
Old Jan 13, 2005 | 09:07 AM
BAD2000TA's Avatar
Default Damaged Clutch Disc?
I received my new Z06 clutch yesterday from SDPC. Apparently, the box was tossed around pretty good, as the clutch disc hit the inside of the box hard. I'm concerned that it could effect performance or the life of the clutch. Please look at the attached pictures and tell me if I'm being too paranoid! Thank you.
Attached Thumbnails Damaged Clutch Disc?-snow-clutch-017a.jpg   Damaged Clutch Disc?-snow-clutch-021a.jpg
Old Jan 13, 2005 | 09:42 AM
LOnSLO's Avatar
I wouldn't worry about it at all. You could always send it back though to help you sleep better.
Old Jan 13, 2005 | 10:10 AM
BAD2000TA's Avatar
I know! It sucks, I certainly don't to have to pull it out again. I'm 99% sure it's fine. But, there is that slight doubt. Thanks.
Old Jan 13, 2005 | 10:38 AM
1999T/A's Avatar
I wouldn't worry about it . My Spec clutch looked like that when I got it . I put it in and 500 miles later its good . Didnt even consider it as a problem .
Old Jan 13, 2005 | 04:14 PM
BAD2000TA's Avatar
Thanks guys!
