4l60E to 6 SPEED
Old Jan 17, 2005 | 07:53 PM
malibu9in's Avatar
Default 4l60E to 6 SPEED
I have searched this AWESOME forum and found lots of info on the swap. However i am a little confused on the clutch/slave cylinder. Everyone says go with the 2001 and up set up..and do a "drilling mod" to this part. What is there to do? To witch part? I have a 1978 malibu with a lt1 but now this car will have a 6 speed in it. I bought a tranny,bell,flywheel,and clutch set up for 800. It is a spec 3 clutch (we will see how that works) . All i need now is the shifter,clutch/slave cylinder. Who is the cheapest on those parts? Thanks Jason (newbie)
Old Jan 18, 2005 | 11:53 AM
DanZ28's Avatar
Not sure if the LT1/trans will need the same drill mod. here is a write up of it though: http://www.installuniversity.com Under "install Documents"/McLeod Adjustable Master Cylinder and "Drill Mod" Install
Dan
Old Jan 18, 2005 | 02:29 PM
malibu9in's Avatar
thanks for the reply i think ill just bolt it on and go and see if that helps.
Old Jan 18, 2005 | 04:32 PM
DanZ28's Avatar
Should be fine, especially if your using a stock clutch..
Old Jan 18, 2005 | 07:09 PM
malibu9in's Avatar
well its a spec 3 ..thats just what came with it...i dunno i want to do it right the first time. The car sees about 2500 miles a year tops so if its not all out race ready thats cool just want it to be the most bang for the buck. thanks for replying.
