installing Spec 3 what else to change
Old Jan 19, 2005 | 07:56 PM
ArticZ's Avatar
Default installing Spec 3 what else to change
Im putting in a Spec 3 pretty soon.. I was just wondering if there is anything else I should change while Im in there. Like the though out bearing or anything like that.. Im just going to resurface my fly wheel as long as it looks ok.
Old Jan 19, 2005 | 09:10 PM
Jabroni's Avatar
If you have a pre 2001 car, I'd swap out all of the outdated hydraulic clutch components. While you're in there, do the throwout bearing and the pilot bearing, too, unless they are close to brand new. A while back, SLP was selling new stock iron flywheels for $100 bucks. If they have them, just pick up a new one. I've heard some stories about the SPEC 3's not liking resurfaced flywheels, but I cannot substantiate that...only what I've read here.
Old Jan 19, 2005 | 10:33 PM
ArticZ's Avatar
cool.. thanks man.. I have an 02 with 30k on so I'll probably just change out the bearings unless the flywheel looks realy bad
Old Jan 19, 2005 | 10:41 PM
Krab's Avatar
You can also get a GM flywheel for about $70 shipped from ebay. While you're in there, I'd change out the hydraulics, pilot bearing and throwout bearing. When you go to install everything back up, be sure to sand down the dowels on the bellhousing that way it'll be easier to take off in the future. And put some anti-seize on them too.
Old Jan 20, 2005 | 12:49 PM
SNAKSLYR's Avatar
I would be prepared for an updated Master Cylinder, and preform the drill mod on it. The Specs like that. Without that the pedal will begin sticking on the floor at high RPM's. Put a new Slave unit in, it's worth doing while you are in there.
Old Jan 20, 2005 | 05:25 PM
P Mack's Avatar
Definately change the pilot bearing. The guy i bought my car from didn't change it and it ended up falling apart and chewing up my input shaft, which is a $250 part.
