OK< HERES THE "CLUTCH" PROBLEM
Old Jan 24, 2005 | 05:14 PM
hothugger99's Avatar
Unhappy OK< HERES THE "CLUTCH" PROBLEM
Ive noticed here in the last couple of months that my clutch pedal goes not quite halfway down before I get any resistence. Here lately Ive been having to pump the clutch from fully depressed to the point of resistance before it will get tight again. Then I am able to change gears normally, but when I come to a stop I have to do it all over again. What is causing this problem?
Old Jan 24, 2005 | 06:31 PM
smokeum99ta's Avatar
clutch could be going or need to bleed the air out of the system. thats my guess.
Old Jan 27, 2005 | 04:23 PM
SSBRONCS's Avatar
I agree with smoke
Old Jan 27, 2005 | 07:09 PM
Wino's Avatar
Mine was doing the same thing. I put an `02 slave in and the problem was solved.
Old Jan 27, 2005 | 07:47 PM
Turo's Avatar
i had a similar problem, mine would lose resistance the longer i held the pedal down (for example, if i was at a stoplight and left it in gear and just held the clutch pedal down). the culprit ended up being my master cylinder.
Old Jan 27, 2005 | 10:22 PM
STL2SLO's Avatar
I agree with Turo...mine was acting very similar to what yours is doing and I replaced the Master Cyl. and it works fine now.
