What shudder????
Old Feb 10, 2005 | 04:00 PM
Y2K SS's Avatar
Default What shudder????
I hear guys talking a lot about clutches and shudder. I'm guessing its when you let off the clutch at low rpm it starts to vibe. Anyway I have a question about that. If your clutch is starting to go out would it affect your rear end also? Evry now and then I feel like a clunk in the rear like from the right side. Probably check the transmount also.
thanks.
Old Feb 10, 2005 | 10:08 PM
wrencher's Avatar
wrencher
No chatter is just that, chatter. The rear end noise is it suspension or differential generated? Either way the clutch is likely not at fault there.
