Spec clutch lightweight option?
The also have a lightweight "aluminum" pressure plate option, which has steel friction surface on top of about 1/2" thick of aluminum to reduce the weight.
Both will reduce rotating inertia to you motor, freeing up some lost HP (just a little). Supposed to be better for auto-x and street use (engine revs faster) but bad for hard launching such as drag racing .
