Any advantages to using a synth. clutch fluid?
Old Feb 16, 2005 | 09:49 PM
FstBlkz28's Avatar
Default Any advantages to using a synth. clutch fluid?
I just got done flushing my clutch line this past weekend and I just used a regular DOT 3 brake fluid. But would there be any advantages of running like a synth. DOT3 approved brake fluid in your clutch lines?
Old Feb 16, 2005 | 10:08 PM
wrencher's Avatar
wrencher
Usually it has a higher boiling point. It is more heat & moisture resistant.
Old Feb 17, 2005 | 12:02 PM
Steve Burger's Avatar
LS1TECH Sponsor
Do a search. The clutch hydros don't like synth fluid. Just use good Dot 3 or 4.
