problem ??!!
Old Feb 16, 2005 | 10:43 PM
baloga41's Avatar
Question problem ??!!
i was racing a guy and after speed shiffting 1st to 2nd the clutch felt light and i could not shift to 3rd waited a lil bit and it was fixed then tried agian the saem thing happened but now worse (from 1st to 2nd) is it the clutch or the pressure plate?? if none what is it??
thanks in advance
Old Feb 17, 2005 | 07:39 AM
Dustin Butts's Avatar
Sounds like a slave cyl problem to me. Are you running all stock hydraulics and clutch...?
Old Feb 17, 2005 | 08:19 AM
Steve Burger's Avatar
LS1TECH Sponsor
Have you done the drill mod?
Old Feb 17, 2005 | 10:14 AM
baloga41's Avatar
yes what should i do???
what is the drill mod??
Old Feb 17, 2005 | 11:44 AM
First you'll need to replace the slave cylinder. You'll have to pull the trans to do this. The drill mod is done to the master cylinder end of the pressure line that feeds to the slave cyl. Go to www.installuniversity.com for directions on the drill mod.
Hopefully your clutch and master cylinder are still good. How many miles are on the vehicle?
Old Feb 17, 2005 | 10:59 PM
baloga41's Avatar
29000miles
Old Feb 17, 2005 | 11:04 PM
Dal1as's Avatar
With almost 30,000 miles on the car I'd just replace the whole clutch assembly. I've been having similar issues and am guessing it's something internal like the pressure plate. I've done the drill mod, wrap, etc. Clutch doesn't slip but take the car into high rpm's and there goes the pedal. No leaks either.
Old Feb 18, 2005 | 12:39 AM
scifone's Avatar
before you go replacing anything... jack the car up and see where the braided line for the clutch hydros is... make sure that it isnt close to the exhaust. that can make the clutch stick to the floor. if it is close then wrap it with some heat wrap and zip tie it up away from the exhaust.
Old Feb 18, 2005 | 04:00 PM
Yeah, might not be a bad idea to replace the clutch too. You have to remove the trans anyway.
