Slave Cylinder Question
Old Feb 23, 2005 | 03:35 PM
98BlackTA's Avatar
Default Slave Cylinder Question
I know this has probably been asked before I did a search and could not find an exact answer. My question is what is the difference between the zo6 slave and the F-body replacement slave. Which one should I get. Thanks
Old Feb 23, 2005 | 03:42 PM
Smitty's Avatar
Same slave cyl.,but different part #'s due to the fact the vette slave's have a steebraided line attached to them that connects them to the master cyl. line.If you replacing the slave on a f-body use the 01/02 version.The apply piston in it is lil bigger.
