Which Clutch to go with???????
Old Feb 25, 2005 | 11:53 PM
A-Bomb's Avatar
Default Which Clutch to go with???????
I need a new clutch. My stock clutch is sticking to the floor. Which one should i go with? Input please.
Old Feb 26, 2005 | 12:29 AM
waltsfastz's Avatar
I went with the Spec 3. Since then I have seen some bad things come from a spec but mine has been real so far.
Old Feb 26, 2005 | 03:05 AM
DanZ28's Avatar
That's the million dollar ? it seems, which clutch. All I hear is spec and seems like it's a 50/50 mix on them, and well, most other clutces as well. If your pretty much stock, just look at the Z06 clutch IMO. if you doing 6K clutch dumps with slicks, look for something like a Spec 4 or Mcleod twin disk, exedy, etc. put all new hydrolics in at the same time...
Dan
Old Feb 26, 2005 | 09:30 AM
A-Bomb's Avatar
i'm reading alot of good things about the Mcleod Twin disc. any input on those?
Old Feb 26, 2005 | 10:10 AM
Mooobunnny's Avatar
I ahve a RAM 910 and it works very well so far. A pretty aggressive clutch, but once you get use to it, it does great on the street.
Old Feb 26, 2005 | 07:32 PM
35th SS's Avatar
twins here.you cant slip this clutch.no rattles after install.he likes to be dump out of the hole.
