Grinding From First To Second When Cold......
Is this a commom problem? Its a 94 LT1/M6 91K Miles - It almost always grinds a little when going into second gear (only second, no other gears) right after start up, once it warms up it shifts perfect, its not a horrible grind just a slight catch feeling, I first thought the second gear syncro's were going out but it shifts great after it warms up, any thoughts?
Chris
-T
But, sometimes when I shift quickly in WOT runs from 1st to 2nd in grinds a bit.......synchros going bad???? And again, the problem doesn't seem to get worst. I've also replaced the tranny fluid like a year ago and it didn't change anything.
