Pro 5.0 hard to shift into reverse
Old Mar 8, 2005 | 09:24 AM
-Q-'s Avatar
-Q-
Default Pro 5.0 hard to shift into reverse
Anyone else have this problem with their Pro 5.0? It's especially hard to shift into reverse first thing in the morning...if I have to shift into reverse again shortly thereafter, it goes in OK. Just wondering if I messed something up during the install or if the shifter itself is bad. I bought it used off of another board member. TIA
Old Mar 8, 2005 | 05:17 PM
99hawk409's Avatar
i have the same problem.
I also have a pro 5.0........
I've been thinking i just need tranny work.
Now i'm not 100% sure.
anybody else?
Old Mar 8, 2005 | 05:33 PM
TheHun's Avatar
Yup hard.
On the other hand manual trans. You can't always find the first or reverse with a stick shift. You need to move the gears, step on clutch pedal again or shift like 1-2-1 if you cant find the first (or reverse)
Old Mar 8, 2005 | 05:36 PM
Poik's Avatar
Yeah sometimes I have to pump the clutch another time and then put it into 1st or 2nd to get the synchros to go or whatever is really happening when it does that. After that it slides in pretty easy.
Old Mar 8, 2005 | 07:22 PM
SSmith's Avatar
same here..hard to get into reverse sometimes and 6th gear is harder all the time. I have to be more aggresive getting it into 6th than the others.
It goes in but just a little more effort required.
Old Mar 8, 2005 | 07:50 PM
black99ssm6's Avatar
Yup same thing here. just put it in first then go to reverse. it helps mine out a lot. i think it helps align the synchros
Old Mar 9, 2005 | 12:00 AM
Armageddon's Avatar
...with cheese.
I just pump the clutch again.
Old Mar 9, 2005 | 03:18 AM
ZR2877's Avatar
I always put a vehicle in a forward gear before I go to reverse. It makes it so much smoother.
Old Mar 9, 2005 | 04:31 AM
JMBLOWNWS6's Avatar
Mine works sweet Its becuase I just rebuilt the tranny
Old Mar 9, 2005 | 09:15 AM
-Q-'s Avatar
-Q-
I tried moving the shifter to 3rd before going into reverse, and it's smooth as silk. Guess I'll do that from now on. Thanks guys, just wanted to be sure I didn't have a junk shifter or something. Out of curiousity, does the B&M Ripper do this as well? Anybody switched?
Old Mar 9, 2005 | 11:24 AM
Hagarr's Avatar
I have the same issue. I simply put it in first and roll a little forward wait to the car either stops or rolls back and then I can put it into reverse. This whole problem pisses me off and have contemplated switching to a different shifter.
Brian
Old Mar 12, 2005 | 09:43 PM
ProjecT 9's Avatar
i dont think i have ever had this problem...ill check next time though, im curious
Old Mar 13, 2005 | 02:44 AM
02WS6Bird's Avatar
This is an issue since the beginning of this Shifters popularity to us F-Body owners. If my mind serves me correctly, it was something about adjusting the stops, and if it wasn't that it had something to do w/ the hydraulics. Otherwise, just live with it, if it becomes impossible, try to adjust it, and if that doesn't work DUMP IT (in the garbage)
Old Mar 13, 2005 | 03:10 PM
2w0s060's Avatar
Yep this is the trick I learned, seems to help
