Missing bolts in T-56?
transmission pictures/
In addition, I noticed that the underside of the transmission has a webbing of lines all over, as if from stress or fatigue, can anyone confirm this from the pictures?
Also, 6th gear shudders when I let off the gas until the wheels start slowing down the engine it seems. The throwout bearing also seems to 'whirr' much more than normal, I guess it needs to be replaced.
I have those "stress cracks" on mine too, I think its just how the metal looks after it was made, not really cracks. It should be ok unless there are actual cracks in the metal.
Those marks are called heat checks and are from wear to the die. If you check, these are all positives= they are ridges not cracks and actually the oposite of cracks. They are only a visual problem ( and rough on the hands when working with the trans). These go away when the die is dressed.
So all three holes circled in that picture require M10 1.5s? Any specific length?
Thanks for all your help!
