Newbie needs some help
Old Mar 15, 2005 | 07:26 AM
lead sled's Avatar
Default Newbie needs some help
First this is a great forum. I have already found a lot of very useful information and it appears that there is an awful lot of very knowledgeable people out there.
My goal: I want to put a GEN III motor into a older Jag and have a manual transmission. I also want to run on reg 87 octane gas as I need more torque than high rev HP.
What I think that I want to do is to find a complete 5.3 truck engine and attach it to a car T56. I like this idea because:
1. Truck engines appear to be cheaper.
2. All GEN III type engines share the same architure.
3. Truck engines do not require 91 octane/premimum gas
4. Truck engines have comp torque numbers
It would seem like this sould be a bolt on affair. I also think that I could use a clutch/flywheel set up from a LS1 car application.
What do you guies think? Is this a workable plan?
Any insight would be great!!!
Thanks Wayne
Old Mar 17, 2005 | 12:02 AM
Gloveperson's Avatar
While I am unclear on your reasoning for only 87 octane, it sounds like it would work fine as long as it will all fit. Sounds like a very interesting swap. There is a conversion/hybrid area of this forum that might be answer this question better, and those guys in that section have all dealt with the headaches I am sure you will encounter. Good luck!
