Leaking Quick Disconnect- different colors?
Old Mar 15, 2005 | 09:05 AM
RX-Ben's Avatar
Default Leaking Quick Disconnect- different colors?
Are all the quick disconnect fittings the same, even if they are different colors? I have a green slave fitting, and a gold fitting on the line, and the connection is leaking whenever the pedal is pumped.
I had a hell of a time getting the fittings to snap together (it finally did) but apparently it didn't seated correctly.
Thanks
Ben
