DID i break my TQ arm?
Old Mar 15, 2005 | 07:29 PM
2000bean's Avatar
Default DID i break my TQ arm?
i think that I may have broke my tq arm today on my 6spd. All of a sudden after I shifted hard i noticed that everytime i hit the breaks i hear a banging and the rearend kinda shifts forward, also if i get on it something is banging. does this sound like the tq arm? i havent had a chance to get under the car and look yet.
whats the cheapest replacement and where can i get it, i need it by the weekend? thanks
Old Mar 15, 2005 | 08:16 PM
DravenMyers's Avatar
I bet your trans. mount is out,the best thing to do would be to look underneath and check for any broken parts.If everything looks ok get a polyurathain trans mount from one of the sponsers and you should be ok
Old Mar 15, 2005 | 08:19 PM
2000bean's Avatar
but would the trans mount make the entire rear kinda roll forward when i tap or hit the brakes? also when i noticed a little wheel hop also after this happened
Old Mar 15, 2005 | 08:27 PM
No it would not do that,thats why you should look underneath and check to see for any loose bolts or broken parts.I would do a trans mount while your under your car because factory mounts suck they dont have to be cracked or broken they will still make noise when shifting I have seen many go bad
