98 and 01 6speeds
Old Mar 15, 2005 | 09:26 PM
ujslost2's Avatar
Default 98 and 01 6speeds
I was wondering if the parts out of a 98 6 speed could interchange with a 01 speed. Reason for asking is the 98 trans has borg warner on it and mine has tremec on it. I know tremec bought borg warner, but i didnt if know they changed anything afterwards? Thanks.
Old Mar 15, 2005 | 09:38 PM
KissMySSo1's Avatar
pretty sure they're the same but not 100%
Old Mar 15, 2005 | 10:13 PM
Mike94ZLT1's Avatar
If you look closely, your 01 will say Borg Warner on it too. Theyre the same trans, and personally I would rather have the one that is newer.
Old Mar 15, 2005 | 11:22 PM
wrencher's Avatar
wrencher
The same.......
Old Mar 16, 2005 | 02:48 PM
Shuck's Avatar
I agree, they are the same, but I think the newer ones got better synchro's and something else though.
Old Mar 17, 2005 | 10:38 AM
oange ss's Avatar
newer has carbon blocker rings, older has paper fiber. Tremec bought out Borg Warner, but the design is the same, the newer should say Tremec on the case
Old Mar 19, 2005 | 10:22 PM
thesource's Avatar
The internals are the exact same . They will interchange with each other as long they are Ls1 units . The Lt1 units are different up front .
Old Mar 21, 2005 | 08:06 AM
88SS LS1's Avatar
There was some problems with the 02 models with alignment with the main shaft, which caused some problems. Not sure if the 01's had the same problem
Old Mar 21, 2005 | 11:00 AM
thesource's Avatar
Thats the first I have heard of this problem .......
Old Mar 21, 2005 | 03:01 PM
calhoon's Avatar
That is the fruit of some ones dream. There were no" mainshaft alignment" issues - ever.
