clutch question
Old Mar 19, 2005 | 09:33 PM
lsp408's Avatar
Default clutch question
i have 02 ss and got cam head hooker long tube centerforce clutch in it. everytime when i bring the rpm to like over 6000 rpm then shift. right after my clutch pedal feel very soft and catches the clutch when i just barely let my foot off instead of half way. but the padel go back to normal after i press couple time. there is no leak. i have ask few people they told me the reason my clutch padel was doing that because my long tube heat up the line cause weak padel. has anyone experience this??? lately i got problem speed shift into 3rd, it won't go in right away, it just happen right after i put royal purple synchomax. the tranny already been rebuild and got carbon fiber block ring and steel shift fork. during normal driving, it is fine. so i am going to change fluid again to see if that help. as far as clutch padel, i might just go ahead put new clutch in it.
Old Mar 19, 2005 | 10:03 PM
shiznit's Avatar
Did you do the drill mod??? If not I would highly recommend it.
Old Mar 20, 2005 | 12:43 AM
mellowyellow's Avatar
what is the drill mod??
Old Mar 20, 2005 | 04:13 AM
8-Pack's Avatar
Drill Mod
Sorry man but your post is al little hard to read, but from what I can gather, your having problems shifting fast into third? Sounds like synchro's. Never used royal purple anything but if it is a thicker oil it might cause your synchros to match up slower, amking it hard to get into gear when shifting fast.
Old Mar 20, 2005 | 09:07 AM
lsp408's Avatar
i don't think i have done, i guess when i get mcloud adjustable master i do the drill mod
