1st gear jerks at acceleration
Old Mar 22, 2005 | 03:31 PM
00Z-28-LT1's Avatar
Question 1st gear jerks at acceleration
i made one pass down the track...i took it easy i thought and now first gear jerks one or two times when moving from a stop. i thought it was one of the springs in the clutch but the entire clutch looks fine so is there any thing in the trans that could have broke to cause this. the car is an m6 with a spec 3 and a b&m ripper.....
and it only does it from a stop, if you down shift into first while moving its fine
does anybody know what the problem is....i want my car back.
thanks
Old Mar 23, 2005 | 05:48 PM
Brandon Boomhauer's Avatar
Generally get that when you put a stiffer clutch setup in. Try reving to 1700 and sliding out...
That clutch is pretty grabby, from what I've heard, just like my RAM Powergrip HD.
