new clutch or just bleed the system?
Old Mar 26, 2005 | 05:48 PM
squall01's Avatar
Default new clutch or just bleed the system?
when running through the gears, by the time i hit 4th, the clutch is disengaging right off the floor. if i pump the pedal in neutral, it works fine again. also, if i push in the clutch, leave it in gear, and rev, it has the same time of effect. this leads me to think that there is air in the line and it's not letting the clutch disengage all the way, causing slippage and heat. also, while out in the drive way, i noticed if i push in the clutch and rev, then let it out quickly, i hear a clunk. i don't know what is goin on. i was gonna try to bleed the system, but I COULDN'T FIND THE DAMN BLEEDER SCREW!!! anyway, any help would be awesome.
thanks,
bill
Old Mar 27, 2005 | 01:31 AM
Krab's Avatar
Sounds like it could be some air in the system. The bleeder valve is located at about a 30 degree angle directly above the line that runs from the master into the slave cylinder. I forget the size of the socket though, but I think I remember it being a standard size (3/8" maybe?).
