slipping
Old Mar 28, 2005 | 06:44 PM
chris77's Avatar
Default slipping
can someone explane how if fills when a clutch starts to slip. i have a spec stage 3, and this past week, when i drive it real, and i mean real easy its fine, but if i try to get on it, then the rpm will shoot up a bit, but i wont go anywhere, it will fill real ruff, then grab and go. so is it slipping, and if so can i just get a new disk.
Old Mar 29, 2005 | 06:27 AM
ace68's Avatar
yes your clutch is slipping unless, your tires are spinning when you get on it! If not then your clutch is shot.
