Problems with shifting at high RPMs
Old Apr 5, 2005 | 05:50 PM
1999T/A's Avatar
Default Problems with shifting at high RPMs
Ok heres the story , I put a new motor in , new clutch , all new hydraulics. The problem did not exist before the new stuff. I cant shift at redline. It wont go into gear until the RPMs fall to 5K , then I can shift. Its frustrating as all hell . I have great pedal pressure , shifts like butter under 5K RPMS. It was pre-bled , I did the drill mod , and bled it ONCE after I got it together. New Dextron 3 in the case .
Do you guys think I need to re-bleed ? Im stumped !
Old Apr 6, 2005 | 09:27 AM
1999T/A's Avatar
TTT , I need some suggestions guys . I searched already but havent found anything that im satisfied with .
Old Apr 6, 2005 | 10:51 AM
Tranzor's Avatar
I'd bleed it again... sounds like you might still have some air in there.
Old Apr 6, 2005 | 02:31 PM
LSs1Power's Avatar
Maybe the tranny is moving too much at high RPM's? Check your tranny mounts.
Old Apr 6, 2005 | 02:39 PM
1999T/A's Avatar
New Poly mounts throughout , motor , trans , and Torque Arm .
