tips on driving manual??
Tris
Congrats on the swap though, I'm about to do the same thing myself.
Other advice. . .practice, practice, practice.
The drill mod i don't believe will be necessary...Doesnt it haveta do w/ a hose or tube that has to deal w/ the STOCK hydraulics? maybe I'm wrong but anywho.
Practice taking off near your house so there won't be any need to worry of the engine dying. TAKE IT EASY on the new cluthc and rear! Take in the proper break in methods. You may want to row through the gears a few times while stationary to get used to the shifter. I'd say accelerate high enough in the RPM range to where you may be able to slowly shift into the next gear as well to get a feel of it, as the practice comes you'll be much quicker w/ it.
Send me a PM Thanks. I'm mostly concerned w/ the price
Do it in a loose gravel parking lot! A WHOLE lot easier on the car if you're rough with it and really teaches control! (turn of tcs if equipped)
Thanks Do it in a loose gravel parking lot! A WHOLE lot easier on the car if you're rough with it and really teaches control! (turn of tcs if equipped)
Man that is a good Idea were did you learn that
15 minutes of driving and she had it... my truck was saved as was my neck and back. Since then I recommend it to anybody/everybody!
If your gonna downshift to pass somebody, blip the throttle while the clutch is in and your putting it into gear so that the car isn't shocked too hard when you release the clutch.
www.installuniversity.com has the drill mod included in the middle of their master cylinder install. (drill out restriction in fluid line so your clutch grabs better and lasts longer instead of slipping/burning no matter how fast you pop it)
Most of all have fun bangin' gears.
Jason
